Camera has problem reading barcodes with neoreader
xperiamusE
My Xperia E is not able to Scan barcodes with neoreader.
My model and a model in a Store have the same problem.
I tested it with a Xperia gio without problems.
The barocde is not sharp when i try to scan, but technical descriptions tell me that the xperia E has autofocus function.
I there any solution ?
6 REPLIES 6
Johan
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
Johan
Unfortunately you can run into this when the barcode is too small.
xperiamusE
Sorry, but i speak about barcodes which are in normal size on packages and readed problemless with other xperia like gio or z in just one moment when the camera of them is detecting that there is a barcode.
The combination of Xperia E and neoreader is not able to read a normal sized barcode. Try it out at your reseller. It is not a problem of my device it is a fundamental Xperia E problem
Maelstrom1
There are a few possible resons for not being able to scan barcodes:
- the camera of Xperia E does not have auto-focus;
- barcodes can come in a variety of formats: see http://mdn.morovia.com/kb/Identify-Barcode-Format-10623.html for barcode formats;
- barcodes can be read using several algorithms, so your problem may be application-dependent.
ssd
Usually for reading barcodes a 5MP camera with auto focus is required, whereas in Xperia E the camera is only 3.2MP which cannot distinguishly see the bars on barcodes that is why you cant scan
P.S. : i'm too facing this problem:smileyplain::smileysad:
andyadams
print pdf417 barcode in .net
Have you tested other scanners with Xperia?You'd better try some other scanners to see if the problem come from the app or your Xperia.
