C510a Conversation function missing.
Not sure what's going on but it's been happening ever since I got it, I would assume software problem on this one, often then sms Conversation function just dissapears and then come back a week or so later, it's really annoying since I use this function a lot. Do I need a software update or patch?
4 REPLIES 4
No harm in performing a software update if it is available.
SE update service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Alternatively you could perform a software repair using PC Companion if you are able to.
Connect your phone to the PC via the USB cable
The repair option on PC Companion (Support Zone --> Update --> Repair)
Jake-SonyXperia
I believe you are accidentally pressing the navigational key when inside the inbox which changes the sms back to default. Simply do the following,
Menu > Messaging > Inbox > Right navigational key. You should be back in Conversations.
Yes, jake was right, found that out befotre I logged back in here haha. Sorry for late reply.
Jake-SonyXperia
No problem. I am glad you have it all working now Slightly_smiling_Face
