C2305BT not switching on with red LED only while charging
Darkboy
I turned off my phone yesterday and after 30 minutes I wanted to turn it on again but it wouldn't start. I tried holding power button+volume up/down but nothing happened. Thought the battery may be drained out so I connected it to a charger and the LED lit up on steady red color but the battery charging percentage wouldn't show up. I've left it for 3 hours but it still wouldn't turn on or respond to Power button+Volume up/down and the LED still shows red while connected to a charger and turns off immediately when disconnected . I also tried repairing it using PC companion but neither the PC or my Laptop would detect it.
6 REPLIES 6
profile.country.PH.title
MarlonUk1
have your device repaired at your local service center Local support
nagarjuna97
Exactly the Same problem as yours.! Please Say me here if you find some solution.. Thanks in advance..
HPSH
I had Xperia C. Every time i switched off my phone. And try to switch it on. It doesn't work. I went to a mobile technician he claimed that the processor should be changed. I did it. The problem is repeated. Then he claimed it was a software problem. He did it. And I restarted it many times after that it went right. Yesterday the contacts and call logs disappeared and I restarted it. It DOESN'T WORK AGAIN. So what is the problem in your point of view ??
Jonas
Hi @HPSH, I'm sorry to hear about your phone. Slightly_frowning_Face
Could you please try and and press the volume up button and the ON/OFF button at the same time for about 10 seconds, this will force your phone to be turned off and you will receive a few vibrations.
Try and power on the phone as normal with the ON/OFF button, is it starting now?
If it's still not powering on I would recommend that you remove the SIM and/or SD card from your phone and then try and start it up again.
Let me know how it went! Slightly_smiling_Face
nagarjuna97
I have the same problem.. I've been doing all what you said in this post for past two weeks but of no use.! Same problem is being found by many Xperia C users round the globe.! Sony Support, You should look into this problem seriously as it is naturally suspicious to find same problem in many phones  @ Jonas
Jonas
Hi @nagarjuna97,
I'm sorry to hear that you experience the same troubles with your phone and other users as well. Slightly_frowning_Face
If you have done the troubleshooting that I and @nolramlb recommended, I'm afraid your phone will have to be sent to an authorized service centre.
I will not be able to assist you with this since I work globally, so please get in touch with your Local support and they will assist you with getting it in sent. They will also be able to answer all your questions regarding warranty, service routines and so forth.
Keep me updated! Slightly_smiling_Face
