i am not able to browse in my xperia arc phone in gprs i.e, using my mobile network operator.it is just 2 weeks old phone,and i was browsing in gprs for 2 weeks without any problem.please kindly reply ,waiting for your valuable reply
There are a couple of things you can check:
Main Menu > Settings > Wireless & Networks > Mobile Networks > Ensure Data is Enabled > Access Point Names > Make sure you an access point name referring specifically to "Internet" in this location and that it is selected.
If you have checked this and the problem continues, you would be best to speak with your current network provider regarding this issue.
Hi!
I also faced the similar problem in my xperia neo v. Bought this phone 2 weeks ago and of late, phone GPRS is not working and i am not able to browse internet though it was working fine initially. Thought that there would have been the problem from service provider side (airtel) but they confirmed that the settings are OK. GPRS works intermittently but does not work most of the time. I had a doubt that the problem could be with SIM so i replaced it with new one but unfortunately no luck.
I noticed that, when i inserted the new SIM, GPRS started working perfectly fine. I felt that the problem is resolved and root cause was SIM only. But the problem continued after some time. This problem started again when i connected wi-fi at home and browsed for a while and again checked GPRS, it did not work. This may be a change point. I reloaded the factory settings but problem remains same.
I am clue less about this problem in my phone.
If anyone has any solution, may please reply.
Thanks.
HI
MAKE A SOFTWARE UPDATE THE GPRS WILL BE STABLE CMMON PROBLEM NOTHING TO WORRY
FURTHER ICS FOR NEO V XPERIA PRO. ETC. ARE COMING ON THIS MONTH OR NEXT SO WAIT AND APPLY IT LL BE OKAY
