Bottom Cap
badxperia
Bottom Cap
Can i remove my xperia p bottom cap ? I did't try that yet. Its colour is fainted already. Is it possible to remove it by inserting some force? And if it is removable from where i can purchase bottom caps ?
4 REPLIES 4
zefs
Yes you just need to apply force. About new ones check on ebay.
florenzgonzales
visit a nearby sony centers or sony stores. here in the philippines there are available caps for our xperia P. You dont even have to force it to be removed. Just pull it gently and it can be remove anytime anywhere. enjoy xperia P!
Namita
same here. mine xperia p bottom cap is loose too. i tried pulling out the cap slowly n it opened. inserted two small pieces of paper at the both sides and closed it. it worked. Slightly_smiling_Face now it quite tight.
But thats not the way. it should be well tight from before. what is wrong with """SONY""". All these problems???? sometimes its call lagging, sometimes phone hangs so bad that i wish to throw it far away. Couldnt make an emergency call due to its call lag and also sometimes cannot receive the call,, only keeps on vibrating, :smileyangry::smileyangry: Please bring an effective update. if no, then stop bringing updates in phone which is further ruining the software. it was quite much better before updating my phone.
SONY ... keep the brand name alive.:smileyconfused:
beeelkuuun
Can My Warranty Covers the Bottom Cap? cause my Xperia P's bottom cap color is also slowly fainting, I don't even scracth the bottom cap nor removing it too often, also my xperia P's color on the left side on the body is also fainting, in which i didn't do anything,It was just place on a silicon cover
