bootloop doesn't charge over 1%
gkorland
After the battery drained I can't find a way to recharge it.
When I plug the phone to the charger it keeps restarting showing "Sony" logo and then shutdown.
From time to time after hard shutdown it does fully restart but with on 1% battery and seems to not recognize the charger (original and not origianl) and then after couple of seconds when the battery full drains again it shutdown.
Also when I try to charge from my laptop (when I manage to make it start) it doesn't recognize that the phone is connected nor does it charging indication is shown.
Tags (3)
3 REPLIES 3
profile.country.RO.title
_alexdon_
It is not recommended to let the battery drain soo much, this might affect the battery phisically. You should be more careful with Li-Ion or Li-Po.
alexdon
gkorland
ok, but what can I do now?
Hampus
If you hold down the ON/OFF + volume up(+) button for 10 seconds, the phone should shutdown completely. If you now connect it to the charger (without trying to power it on), does this behaviour still persist?
