You need to make the Z1 visible to be able to pair.
What kind of device is this Motorola? Is it a phone, Bluetooth headset or anything else?
Hi, It is a Motorola headset(about 5 years old). I have also a tried to connect another bluetooth car set, on my phone the message is it cannot find any device to connect to, even though I have the bluetooth device turned on and sitting beside my phone.
I have the bluetooth device turned on and the bluetooth settings on the xperia turned on.
Is there a setting in the phone I am not turning
If the headset has been paired with another device before it may need to be reset prior to being put back into pairing mode. Please also bear in mind that as the headset is about 5 years old this may also be a compatibility issue.
