Hi. Got a new Z1 compact but am having problems with Bluetooth.
Phone has been paired with the car's bluetooth kit but when car ignition is turned on connection appears to be made and Bluetooth icon in notification bar goes white. After a few seconds it then greys out again.
Car kit works successfuly with other phones.
Have tried deleting pairing and re-pairing the car kit but same problem persists.
Has anybody any other suggestions?
I want to avoid having to try a full reset.
Are there any files I can delete using something like the Total Commander app to force the phone to rewrite setting files for bluetooth?
Thanks
The first thing I would advise doing is check with the carkit manufacturer to see if it is compatible with the version of the Android OS your handset is running, please let us know how that goes.
I think you're a bit back to front there.
I don't think the version of Android my phone is running is relevant.
The car kit doesn't comminicate under Android, it communicates via Bluetooth and the version it uses is the version it was programmed with when it was manufactured and installed. It's a TH Bury Take and Talk kit, very widely installed as an after market Bluetoth handfree kit.
The phone and Android will use a newer version of Bluetooth but will (should) have backwards compatability built in to all the previous versions of Bluetooth. The onus for compatibility falls on handsets as the handsfree kits have no way to be updated.
Are you saying the phone isn't compatible with all versions of Bluetoooth?
It should be, just as every other recent phone is.
Is there a way I can delete Bluetooth setting files on the phone that the phone will then rebuild?
I'm thinking a setting file might be corrupted.
I'm open to suggestions.
Thanks
i have the same thing with my bmw, the arc s worked fine as did my last three sony phones the z1 compact has connected and made calls but if i turn the car off and back on it goes into the 4 second loop searching and will not make calls the only difference i can see is the throw keeps dropping out,
@alan9m wrote:I think you're a bit back to front there.
Thanks
As far as I can see there appear to be many people reporting Bluetooth connection probelms running 4.4 KitKat. This seems like it may be an Android issue or an Android + phone Bluetooth hardware issue.
I'll try to find the links again and post later.
