bluetooth problems, pictures problems ect :o(
i got my new phone yesterday and i love it but i must admit im having some problems with it
1st my bluetooth, other phones cannot find my phone even though i can find them, i have made sure the bluetooth is turned on and it is visable but still nothing.
2nd when i go to set a picture as a wallpaper it ask's me to crop the picture, but sometimes i dont want to, i would like the full picture. even though i do crop some once i go back to my main screen it seems to have zoomed in even larger and im losing half of the picture.
3rd can i change the theme? i cant seem to find anything on the phone that states 'themes' i do not want it blue, i want to change it.
any advice would be very helpful
13 REPLIES 13
Er_Kannan
Hello Clifford,
The problem is caused due to the older version of android. When we get upgraded to éclair the problem might be solved.
But don't worry there is a method to transfer files between your phones. Go to the market from your phone and search for "blue tooth", you will come up with software named "Blue Tooth File Transfer". Download and install this application on both phones and you will be able to share files with ease.
suze
Leader
Hi Clifford
I read your post earlier and didn't know what to sugguest but I have just stumbled across  this... in your Bluetooth File Transfer programme if you press Menu>Settings> there is a Receiving Service tab called (OPP) which is the same as the error you are getting.  I wonder what settings you have on yours that is maybe stopping it.  In a vain attempt at helping cos my BT seems to work OK I'll post mine in case anything is different on yours...
Enabled                 Checked
Start At Boot          Unchecked
Stop When Close    Checked
Show Messages     Checked
Alert on REceive     Check
Destination Folder     /sdcard
Concurrent Connections 1
use bluetooth file transfer...its work like u do copy=paste in pc...
n i hav same wallpaper problem... if sm1 know solution plss let us knpw.....:smileywink:
Will this app fix the lack of connection to my nokia ck7w carkit. Connects for mins then drops connection, even though the status bar inicates it connected, and it aint...
