Hello,
after the Update to Android 4 I can not pair my Arc s with Toyota Avensis Bluetooth (2010). With the old Android 2.3.4 everything works fine. After searching the Toyota Bluetooth Kit and I try to Connect I get a message "FAILURE" from the Toyota Bluetooth Kit. I try to repair the Phone with Companion but the problem is still the same. I can not connect the Arc S with the Bluetoot Kit.
Sony Support doesn't know the Problem. Has anybody these Bluetooth isue too? Does anybody know how I can solve the Problem?
Thanks for your Help
i have a ford fiesta titanium 2010 model.
due to my x10 was in warranty and broke down ,sony gave me an xperia arc....but i cannot pair with my car by bluetooth .... the pop up window to enter the pin code the car gives me never appears on the phone...android version is 4.0.4 with kernel 2.6.32.9-perf builduser.
i dont know my ford car audio bluetooth type but it pairs with any other phone i tried to....i tried all the tricks listed above to make the pairing but nothing works.i dont know if this is problem of android 4 or of arc or anything else the point is that my car recognize the phone ,tell me to put the code and the phone is not responding by giving me the pin code screen
sony you have to ckeck this out....so difficult for you to fix it and update a patch??????
Worked like a charm!! Thank you muchly!!
marcin's method worked for me in my fiesta zetec...
i do this but nothing...
1 get in the car
2 turn on bltooth on xperia arc
3 turn my car on
4 search by arc bltooth the devices
5 when i find FORD AUDIO i click
6 then on the screen of the car apears the pin code to put on the phone
7 on the phone no pop up windows appear to put the pin
8 while the screen of the car appears the the code i open my phonebook
9 i select a contact and i press send by bltooth
10 it appears the screen tht looking for devices to send the contact
11 .......the phone is searching .....and no devices found....:P:P:P:P:P:P
...................so when i am trying to pair the phone no pin code page to enter it nad when i send the contact the phone cannot find the car......great!!!!!!
This is how I did it.
1. Create a contact called bluetooth.
2. Turn on ignition.
3. With my phone, went to contacts, clicked on bluetooth contact, send contact via bluetooth.
4. Found Ford Audio, clicked and the code function popped up on my phone.
Hope this works for you...
Also try updating the car's bluetooth software. There are instructions on the ford website.
i tried everything...but nothing.i managed to connect other phone with android 4.0.4 and connected----so THE PROBLEM IS SONY'S----------------------i downgrade the firmware to 2.3.4 and the phone can connect....
they are so funny-----the gave out a softaware incoplete. i called customer of xperia..they told me it s the first time they were hearing that....do they ever read the forums?-----roll out a patch sony...!!!!!
you are just a name with no reliability any more sony
I tried to pair my handsfree bluetooth by setting up the bluetooth contact and then sending via bluetooth as suggested by spodster and still no luck, still unable to pair and connect.
Sony Germany Support´s answer to the Problem with the missing code input after upgrade to Android 4.0.4:
yes, there might be problems.
No need to comment.
