bluetooth problem in xperia go....
iamlester
just updated my xperia go last week ago from ICS to JB too...
but yesterday i just found out that my bluetooth doesnt work ( not discoverable, always OFF )...
is there any of you guys has the same problem?
any suggestion guys on what should i do???
thanks in advance....
6 REPLIES 6
Michael-J
I would suggest a software repair. This can be done via the PC Companion. The following link will help with this: http://talk.sonymobile.com/thread/54636
What do you think about this forum? Let us know by doing this short survey
majestyalaine
My problem is Wifi and Bluetooth
-The WIFI on/off switch is sometimes in sort of a "disabled" color. I can switch it, but nothing happens and it remains in this color. The other times the color is ok, but as soon as I try to switch it, it again gets that color! I believe it is "trying" to turn on the wifi, as this is the message I get when trying to turn on the "WIFI Hotspot" too. then after a minutes it will restart my phone and restart and restart.
- The Bluetooth on/off switch, cannot get switched on; It immediately jumps back to its previous positions (off).
Please help me sony...
pericles
hello my name is péricles and I had the same problem with my xperia go, I solve it going to configuration, back up and redefine configuration, this will erase your previus config. but this will not unistall your apps and this config. are easy to put again, it has been two days since I did that and until now it´s working fine, hope that helps.
nikoM
Try restarting your phone. I experienced that in JB too.
ben269177
New
Thanks NikoM ,same problem and that sorted it.
ozoffi
Hello!
I pair in my car my Xperia GO with Ford Sync, TomTom Go600 and occasionally a BT OBD adapter.
In principle, this also works . Unfortunately, it often happens that BT " hangs " in the phone. Then either no device is connected , or coupled to one of the devices , while others find no cell phone .
BT is displayed on the mobile phone to be active, but seems to be inactive - but can not off / on ...
As always helps only from mobile / turn - on - sometimes 2x in a row until everything works then .
In addition to BT , depending on the function of the paired device is mobile data traffic and BT Thetering , or Wi-fi turned on.
If the relevant BT device cancels the coupling , the dependencies are to be turned off - I used only Tasker , now Smart Connect - plays no role in the crash.
If I manual on / turn off everything crashes BT as well, but much less frequently from .
If only one device - eg. Ford Sync - coupled there is no problem.
As it so basically always comes to BT crashes , so actually the firmware in conjunction with BT seems to have problems - it's just me?
Allegedly not be suitable for the xperia go and BT android 4.1.2??
Regards
Oliver
