Bluetooth caused reboot loop
new_neo
My xperia neo v phone is having build 4.1.B.0.587,ICS.
Today when I turned on bluetooth on my phone,it suddenly went to reboot n from then on its continues to reboot.
(no file transfer was made,just on turning the bluetooth on.....it crashed)
I could only see SONY.....XPERIA...lock screen for hardly 2-3seconds and then again SONY...XPERIA......SONY.....i.e reboot loop.
What could be the possible cause?
Plz suggest a fix for this issue.
15 REPLIES 15
Sam
Legend
Legend
Please try running a repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
sankytrublu
me too got the same issue and this is my 3rd time.
Please give the proper update
nabs
Sam, software repaires at home or at service centre does not help. Once this problem occours it keep on repeating randomly. Only solution to this problem is to downgrade to Gingerbread.
victoraps
Suppot guys always say the same..........  It happens to me once, i just reflash my GB tft.  Yes i know, they should fix all of this, but they will not.  They will never gonna release a nice an stable rom.  Because, obviously they do not know what they're doing.
pharandeamit
Fu..k That means there is no solution yet for BlueTooth Bootloop Angry_Face Why Sony U Doing this :smileyangry:?
CGGneoV
I think there is really a compatibility issue between the ICS firmware and the Bluetooth firmware of Gingerbread. This reboot loop happened to my Neo V twice, before I came to a conclusion that it was the Bluetooth which caused it. Luckily, I was able to repair it, thanks to the instructions provided by Xperia Support. I hope Sony would be able to fix this issue.
victoraps
They will never gonna fix this, they already got your money.
They do not care.
P.S. Support guys can't help you.
Sam
Legend
Legend
As this is not a common issue across the board with this handset on the latest firmware I would have to advise that you return the handset so that it may looked at by an authorised repair agent given that the repair has not fixed it for you.
viveknair552
Hi, Im facing this issue 3rd time
I have repaired the software using PC Companion and using SUS , but it stays same as if a dog's tail again if we switch on bluetooth the boot loop occurs , SAM what you have to say on this take it to the Service centre and spend money ! how can i downgrade the OS. Really Pissed off.!!!!
