Hi Community,
someone can give the correct procedure or guide to calibrate the battery of Xperia Z2 after Lollipop update?
Thanks to all...!!!
I don't think there is a special way of calibrating the battery (the term is also wrong as far as I know because Li Ion or Po batteries don't need calibrating). Make sure to full charge the device several times (and don't let it completely discharge).
to calibrate I mean calibrate the software and not properly the battery. In particular, I refer to calibrate the part of software that is responsable to shows the correct level of charge. Some manufacters indicate to do a mountly cicle of complete charge and discharge to mantein correct the indication of charge level of the battery icon in the status bar.
Please, I asked about this if Sony have some guidelines to mantein affidable the indication of battery charge.
Thanks again
Sorry Alexdon, but the link doesn't answer to my question... 😕
I am sorry then but I do not understand exactly what you need. There is no calibration,hardware or software,for this battery. There are tips that should be followed if you want to use it more:
http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
