Strangely since 2 days whenever I enable stamina mode it use to get enabled via widget but on status bar the +plus symbol only appears after dropping to specific battery levels.
Then I went to check battery levels I was shocked to find Battery usage showing flat & in negative values and everything to zero like wifi, network signal etc.
I have booted in safe mode and its doing same.
I have reseted the service of Stamina mode by clearing cache etc. but have kept my phone for charging before rebooting it.
But how to resolve this issue about battery usage??? I want it back to be recorrected as it was before.
Do I need to reset or clear any more services??
I'm on Lollipop 5.1.1 23.4.A.0.546
This looks quite strange, may you try suggestions mentioned in this post?
I think a phone repair via PC Companion would resolve that, but try the simpler solutions first.
Well I went to that page but the instructions are unclear.
It say...
On Xperias with built in / embedded battery
The way to force shutdown varies with phone. To find the correct way go to Support > select your phone > Select "User Guide"
So theres no Support or such option in my phone so where m I suppsoe to go???
Not sure about that, because you charge at time x, then forward phone's time to x+100. Battery consumption is a formula based mainly on time, I think you know what caused the issue and this should be fixed when you charge your phone on the corrected timing.
