battery problems lollipop.
Mrcrown
Lollipop made my Xperia z3 compact worse. When my Phone is fully charged the battery is dead after 8 10 hours. Even with the stamina mode on at 100%. Charging the battery takes 3 hours. With kitkat it was less than an hour. And my Phone whas on for at least 2 days. Now i have to recharge 2 times a Day. I made a factory reset, install lollipop again with bridge.
Kitkat is so much better. Thank you Android for my Phone, Thank you Sony for giving us an update that decrease the Phone en not Letting me downgrade to kitkat. When i search on the internet for this problem, i see im not the only one.
18 REPLIES 18
Mrcrown
Uliwooly, it seems like that it fixed the problem. Battery life looks like much better now l, even with stamina mode off. What is the different between the yellow button and the factory restore option in the configuration menu?
I'm glad to hear that Slightly_smiling_Face
Goateye1
What yellow button??
Mrcrown
@ goateye
Where you can put your simcard is a tiny yellow little button
@Goateye  like @Mrcrownsaid under the SIM card cover/flap
Jono_z3c
Since I installed Lollipop, if I try to charge using micro-USB cable connected to a PC, it takes 6-7 hours !
Very disappointing charge times.
@Jono_z3c
That's normal, you have to check the voltage output on the USB port. also it will always take a LOT longer to charge a phone through a computer. again, that's normal
lengyellmeister
Hi guys,
do U have some idea about battery calculation method in Lollipop? Is slightly different from kitkat, or something is with my phone. The Android Operating system and Messenger is the biggest consumer under lollipop, thus these were some % before. Currently Screen is 8% (40 minutes on), AOS is 13% Messenger is 26%. I'm running on .726 via OTA (before I've updated via PCC for .690 and done factory reset after..)  Any idea? Thanks
Mrcrown
I still think that the battery is decreased by lollipop.
Butt there are some things what you could try like i did.
1# the yellow little button like uliwooly said.
2# go to your wifi settings, advanced options and turn off scanning always available.
3# go to your active
apps and look wich apps are on, the one you dont use disable it.
