The battery backup is very low. However the specification says the standby is min. 200 hrs. But my battery runs before that (22 hrs when kept idle)
May i have any suggestion. How to improve battery performance?
Using: Xperia Mini pro
Thanks,
Sravanthi
http://www.sonyericsson.com/cws/products/mobilephones/overview/xperia-mini-pro?cc=gb&lc=en#view=feat... This standby time is under laboratory conditions only, as stated on this page under the network specifications, which therefore doesn't apply in other cases.
However, the battery does become more efficient after several charge/discharge cycles, although don't expect too much from android phones anyway whose batteries only last 1-2 days at best.
Hello Chris,
I donot agree with your words, because initially when i took the mobile the
battery lasted for 3days max...But from last few weeks it is giving only
14-20 hrs of performance.
Please advise
Thanks,
Sravanthi
Hi, hope the following helps ....
- Thread moved to the correct community -
i thinak you could try External Battery Power Bank check out from http://www.goodsinchina.com/apple-accessories/iphone-4-4s-accessories/battery-for-iphone-4-4s.html
