Hi shahnam
What power source are you using and are you using a sony cable?
What about the adapter? Is it an original one?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
