battery life problems after update
Sam1105
Hello Everyone,
after the update with version 14.1.G.2.257  myn lifespan of the battery hasn't improved but got a lot worser.
All the other changes are noticeable and oke but the battery isn't i hope you can fix this problem.
4 REPLIES 4
SwitchTrix
Did you have Stamina Mode enbaled prior to the update? If yes, you will need to re-enable it.
I haven't noticed any significant battery life changes following the update.
MUSHARAB
Me too haven't noticed any significant improvement in battery life, You can check this link to see the BATTERY TEST RESULT with new firmware 14.1.G.2.257
http://talk.sonymobile.com/t5/Xperia-Z1/BATTERY-TEST-RESULTS/m-p/426099
Click kudos.jpg if you think I am helpful . .  .!!
Mystic
honestly ive not noticed anything bad with the battery life. after using an s2 for what seems like forever (3 years) i finally switched to something with a lot better battery.. so basically anything more than 6 hours was great for me Face_with_stuck-out_Tongue_&_winking_Eye im running 18 hours + on a single charge so im happy... i really dont expect a smartphone with all the running apps and data to run more than that...
I can however say that if i turn off data and just use wifi once in a while along with calling (no games) i can get it to last 2 full days.
samsam1105
Well when I just got myn xperia z1 before the last update. Myn z1 could run 2 days with stamina mode on. Now after the update I am glad when it is like 18 hours so what's making this bug happening???
