Hello Everyone,
after the update with version 14.1.G.2.257 myn lifespan of the battery hasn't improved but got a lot worser.
All the other changes are noticeable and oke but the battery isn't i hope you can fix this problem.
Did you have Stamina Mode enbaled prior to the update? If yes, you will need to re-enable it.
I haven't noticed any significant battery life changes following the update.
Me too haven't noticed any significant improvement in battery life, You can check this link to see the BATTERY TEST RESULT with new firmware 14.1.G.2.257
http://talk.sonymobile.com/t5/Xperia-Z1/BATTERY-TEST-RESULTS/m-p/426099
Click if you think I am helpful . . .!!
honestly ive not noticed anything bad with the battery life. after using an s2 for what seems like forever (3 years) i finally switched to something with a lot better battery.. so basically anything more than 6 hours was great for me
im running 18 hours + on a single charge so im happy... i really dont expect a smartphone with all the running apps and data to run more than that...
I can however say that if i turn off data and just use wifi once in a while along with calling (no games) i can get it to last 2 full days.
