Hello everyone,
I've noticed that whenever I charge my Xperia Z3 via dock the battery management graph is not being refreshed. That is, the graph continues it's time (y axis) even after you pulled the charged out (when it should refresh to 0 time as it is when charged via normal port).
This means if I always use dock charging the graph would span on days and days on battery when it's actually being charged, even multiple times, within that span. My main problem is that the graph became hard to read on particular point when the span is so wide (well, if it can only be zoomed).
Is this normal (i.e. a universal bug)? Thanks!
That's odd, restart the phone and check again
Do you charge it above 90%? Try settings-apps-all-eco mode controller,force stop and clear data.Restart and check again.
