Battery drain and SD card problem
hamishjames
Hi All,
In the past week my battery has started to drain very quickliy, ie full charge at 12.30, down to 59% by 17.00. and had not been using the phone, only thing i have done recently is activate google now, I disabled this in case that was the problem but no change. Anyone had battery issues with Skype app or any of the google apps? Also for no apparent reason my SD is dismounting itself unexpectedly any ideas?
thanx
4 REPLIES 4
Von
Sam
Legend
Legend
Regarding the battery problem, please provide a screenshot or just note down the details here of the same screen above (Main Menu > Settings > Power Management > Battery Usage).
For the SD card issue, do you have a secondary SD Card you can try in the phone to narrow down the cause of the issue?
What are your thoughts about this forum? Let us know by doing this short survey.
profile.country.RO.title
_alexdon_
Android OS is draining too much battery,do you have any apps that could be acting up?
alexdon
Von
I think my battery is showing better performance after a few costumizations. 15hours of use, only 4% is lost. As you can see my post above, but I wonder why my OS is draining too much. I only have a weather widget which only refreshes every 2hrs and I leave my MobileData always on for gmail and FBmessenger.
