battery discharging
edric_jhs
battery discharging
Any suggestions? I recently updated my tx to firmware 9.2.A.1.205 and after that night I charge to 100% but after I unplug it and leave it there for 1hour the battery has drain to 92!!!! Is it me or the I udpated wrongly??
2 REPLIES 2
Hampus
I suggest that you charge your unit to 100% and then use it normally until you have 5-10% left on the battery. When you have 5-10%, go to Settings > Power management > Battery usage > Here you find a list of what have dragged battery since the last charge.
If you can't find anything abnormal here, I suggest that you check the following link:
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874
faisal3dfx
Hi I had the same problem after update of 4.3 now I've done a factory reset with full erase of internal memory. After this my battery life has improved but you need to be patients as your phones battery may need a week to sattle down. So I guess you may try for once to do the factory reset with full wipe of internal memory. Plz make sure you backup everything before doing this.
Thanks & good luck.
