Battery Charging Issue
sumitbaran
When I charge my Z1, its stop charging after 82% or 83% only. Please help.
8 REPLIES 8
profile.country.RO.title
_alexdon_
Have you recently updated?
alexdon
sumitbaran
No, But I resolve the issue after Repair through Sony PC Companion.
_alexdon_
So the problem is solved?
alexdon
sumitbaran
Not solved. Its stop after 84% charge.
alex00752
Try  a reset by pressing power button and volume up key at the same time until the phone vibrates three times. After that see if it charges up to 100%
sumitbaran
Ok, I am trying this.
sumitbaran
No, Its Stop again.
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
If the above does not help,you need to visit  sony service.
alexdon
