hi guys
i have a unlocked neo. i tried legacy xperia rom . but then return stock rom. that time this %100 problem appeared. i try to remove battery for 5 min and wipe battery stats but all things are same.
what can i do for fix this problem. can you help me ?? please help me
Repair using Sony Update Service...
thank you for your reply
i tried it but it did not help me
all stock ics kernels have same problem. GB .62 kernel fix it but i dont want use it
Disable system notification and try battery bot...
https://play.google.com/store/apps/details?id=com.darshancomputing.BatteryIndicator&hl=en
Is ther any solution to this problem, I am having same issue in my Xperi Pro after flushing LegecyXperia CM11
i have same problem with me phone xperia neo v after legacy xperia how to disable the battery notifiacation
