Hard to explain but here goes
batterry usage graph
what does the green line mean on the graph?
also where is shows wi fi
awake
screeen on
charging
how come there is some blue lines and some white lines well clear lines
what does it all mean
also what does discharging on the batterry mean
mine says 6hrs 33 min
Where it is green,it means you had signal,where you can see a straight line up the phone was charged.The battery discharging means how much time you get until the battery will discharge completely.
what about at the bottom where it has blue dashes and then clear screen where wi fi.awake,screen on and charging is
is there a user guide explaining all the stuff about the phone
this look at bottom what's all that mean
Where it has blue dashes the phone has been used.,where it has little individual green dashes it has been charged.
thank you so the white clear one's is where its not been used
Can you upload a picture somewhere and send me the link?
if you look on picture above this post you see clear then blue dashes
The picture must be approved by a mod before I see it.Upload and give me a link.
