my battery was stuck all day on 50% , and now the phone turned off and its not starting again !!!
This doesn't sound like a mA issue but more of a charger issue or phone issue, so either your charger is not working or not providing and power or maybe just enough to register power or your phone has an issue processing the power and directing it to your battery for charging,
I'd try different chargers or connecting to a USB port on a Pc etc and if that fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Its not even conecting to the pc .... Its like restarting again and again when i conect it to the pc
and if its to a charger so it always give the low battery screen
Hi Ghhidmi,
Welcome to the community,
Try holding down the Power Key and Volume + key for around 30 seconds, once done try putting the device back on charge to see if this helps start the charge process.
I did its not helping ... The phone is always showing the red battery picture
Is the device still restarting? or is it now simply staying on the charge screen?
