Do you have a screen protector? Can you check if the same occurs in safe mode?
Turn off and turn it back on. Apps will be back.
You didn't reply to my question that's why I have asked. Remove the screen protector and check how it is.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Just to clarify, is the handset going into standby straight away or after a period of time and does the display wake up if you tap the power button whilst on a call?
