Bad work
Eslam3
Bad work
My Sony Xperia Z3 compact mobile always sleeps the screen just when I make a call !!
May I know what's going on ??
11 REPLIES 11
profile.country.RO.title
_alexdon_
Do you have a screen protector? Can you check if the same occurs in safe mode?
alexdon
Eslam3
I checked the "safe mode " and I am still suffering this issue !!
Eslam3
And now I don't know how to restore my apps after the safe mode
_alexdon_
Turn off and turn it back on. Apps will be back.
alexdon
Eslam3
Yup, I have..
You can give me info better than asking me every 20 min.. I appreciate my time.. Plz
_alexdon_
You didn't reply to my question that's why I have asked. Remove the screen protector and check how it is.
alexdon
Eslam3
I removed it, but I still have the problem.. the screen still sleeps when I make a call..
I even can't end the calls !! Or use speakers 🔊 and all the call options during a call !!
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
Sam
Legend
Legend
Just to clarify, is the handset going into standby straight away or after a period of time and does the display wake up if you tap the power button whilst on a call?
