Bad audio on calls after upgrading to Lollipop
corneliu01
Hi everyone. After I upgraded to the new Lollipop software the audio is very bad on calls. I can hear the people that I am talking to very well, but they can not hear me almost at all. This happened right after I upgraded. Please help.
5 REPLIES 5
SophiaW
Enthusiast
Hi corneliu01, welcome to the community!
As you say this happened right after you upgraded the software, I advise running a software repair on the handset as this will re-install the software and is quite likely to resolve this issue for you.
To do this you just need access to a computer with an internet connection.
You will need to download either PC Companion or Bridge for Mac.
Note: a software repair will delete all user data, to back
up your phone:
using PC Companion
1. Go to Support to install PC Companion on a Windows
computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
(Exactly what contents will be backed up may differ
depending on phone model.
You can view detailed information about this as you follow
the steps in the Backup & Restore wizard).
using Bridge for Mac
1. Launch Bridge For MAC.
2. Select "Back up your Xperia device".
3. Select the data you wish to back up from your device
(the windows can be expanded for more detail as below;
then select "Next".
4. The backup will now be in process, do not disconnect
the phone while this runs.
Running the software repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
Running the software repair on Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia
Device".
3. Ensure the phone is charged and select "Ok" in the
following window.
5. Wait until the initialising step is finished the
continue as below.
7. Follow the connection steps that appear, ensuring that
you are holding the relevant button down before during and
after the connection phase until the update/repair begins.
Hope this helps, keep us updated Slightly_smiling_Face
corneliu01
I runed thw software repair and the audio on calls is still bad on the other end (people ca not hear me) otherwise the audio is good on filming and recordings. Please help me fix this. It's a real problem Slightly_smiling_Face
corneliu01
Thank you for your help and patience.
corneliu01
The other people hear me interrupted like when you don't have signal. I have very good coverage. This is happening at the same places that it did not before upgrading.
SophiaW
Enthusiast
If the software repair hasn't helped I then advise contacting Sony Xperia Customer Care  - just click the link in my signature to find the contact details for the team in your region.
