I got a replacement z2 from the retailer i got it from because the vibration was making a strange noise, the new one is like it should be but i have light bleeding in at the top of the screen. Does the warrenty cover this? I probably wont send it off just yet because its not affecting the general use of the phone but i will want to get it sorted eventually.
Another thing i noticed is on a full charge estimated battery life is only 20 hours. Shouldnt it be more then that?
Can i get some help here please
20 hours in stamina mode? About that light bleed,could you post a picture?
No, 20 hours with no power saving functions on. The last device i had said a day and a half or somewhere around that.
I will post a pic of the light bleed
The standby time is just estimated according to your actual usage.You could try to clear data for eco mode controller and restart your device.Enable stamina and disable it,see if anything is different.
How do i do that?
Im about to add these light bleed pics
Settings-apps-all-eco mode controller.Do what I told you before.
Thanks that sorted it out, now it says 1 day 19 hours on 68% battery.
Now just this backlight issue
