when i apply a little bit of pressure on the back glass, (for example for cleaning the glass) its start to make sounds, like clicking sounds, on the front it does not happen, just in the back, the sound is like when you have a door and you need to oil the hinges.... is it normal ??
another thing, when i apply pressure on the sony logo, its like you can bend it to touch the battery inside.. does that happen to you too ??
I'm super dissapointed so far from the build quality, i got a faulty screen (white horzintal hue on the bottom + few dead pixels) and now that cracking noise!
anyone else with the same problem? or is it normal ?
Take it to a Sony repair center ASAP and keep it awary from liquids http://www.sonymobile.com/global-en/support/contact-us/
so it is not normal then...?
