- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
May 2015
May 2015
back and home button dissapeared
I've not updated but all my keys have disappeared at the bottom of my z3 tablet compact I've factory reset which solved it but then 10 mins later it happened again. can anybody suggest anything
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2015
May 2015
Have you installed any custom launchers etc?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2015
May 2015
I tend to just keep it minimal and how it comes out the box the only thing I did was restart the device and they dissapeared and exactly the same after a factory reset
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2015
May 2015
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
