automatic reset the brightness setting /
Hello Community,
Unfortunately, my English is too bad around here to search for existing Tieteln who may already treat my problem. Therefore, I write it this directly. Please do look after me if I so newly created an ever aufgegriffenes topic.
Since I can only work übersetyer by Google here last it a live bask task.
My Z3 Compact can be adjusted in the settings in brightness. (This I tuhe on the fast settings) Even then I choose the intrinsically creates "adapt to the lighting conditions" always off.
After some time, this attitude disappears. The tick is removed, and the regulator adjusted down to about 20%. A regularity so far I could not identify. This I watch now since about 8 weeks. Particularly annoying is that when it is very bright because man can no longer be seen on the display, and can only try blindly to get back into the brightness settings to adjust the brightness again.
Are there perhaps a setting somewhere that this automated switch off? At first I had the suspicion that it had to do with the state of charge of the battery. This, I take it out now though.
I am pleased with answers.
Phy
Legend
Legend
Do you experience the same issue while on safe mode?
How to boot on safe mode
