AT&T Experiences and Tip
ply17410
My phone had ICS on it out of the box.  My MediaNet data plan provisioned SIM worked with the phone.  However data tethering would NOT work although the same SIM in my Xperia Ray running Gingerbread would allow tethering.  Also data speeds were averaging only 2Mbps which was very similar to my Xperia Ray but the Acro S is capable of 14.4Mbps vs the 7.2Mbps of the Xperia Ray.
It appears that there is something about the ICS update (and AT&T) that prevents tethering when using the AT&T MediaNet data plan vs. a true smartphone data plan from AT&T.  The same thing happened with loss of tethering when I updated my Xperia Ray to ICS.  I had to send it back to Sony to go back to Gingerbread, after which tethering worked again.
The phone has a default mobile network setting to use the wap.cingular APN.  So I had my SIM re-provisioned with a 'true' smartphone data plan but tethering still would NOT work.  Also data speeds were still slow.  Since AT&T does not sell the Xperia Acro S, you get provisioned with a generic smartphone plan were you still must use the wap.cingular APN.  Tethering is allowed if you are provisioned for it, but it would not work because of the T-Mobile operator settings that were 'stuck' on the phone (see last tip at end of this post for dealing with this).
I tried the Settings menu option under Xperia ... to get mobile operator settings and noticed that it pulled in the phone APN settings.  This is what the iPhone and many other AT&T phones use.  But I could not connect to data (got voice only).  The generic smartphone data plan does not allow you to use the phone APN.
So I had my phone provisioned as if it was an iPhone 4S.  That allowed me to use the phone APN.  Data speeds instantly were in the 5Mbps on average and I've seen speeds up to 8Mbps.  Never saw anything close to this using the wap.cingular APN.  Tethering now works too once I followed the below 'Last Tip'.  (what a mess)
Last tip ... there was a confirmed bug in the ICS version shipped on the phone where the default T-Mobile operator settings could not be deleted.  Even after updating to the latest ICS build.  I found that you MUST factory reset the phone after the ICS update and then the T-Mobile settings were automatically removed.  You must get the T-Mobile settings off the phone in order for the above iPhone data plan to correctly work for tethering and optimal data speeds.
Regards,
Bob H
reeser8
Bob, what is the phone APN?  I'm trying to get a new Xperia Mini Pro, which had ICS stock, to work as a Hot Spot.  I can get it to tether to my computer using USB, but not as a WiFi HotSpot.
I read the other thread where you were just sending your phone back turn it back to GB.  Based on numerous other sources I read, it appears that you need a special, separate APN, with "APN type: dun" to get data to flow correctly.  Here's my solution to getting the USB tethering working, but unfortunately it's not working for enabling a WiFi Hotspot.
Can you please share with me the phone APN?
FIRST APN (radio button on this one)
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:WAP@CINGULARGPRS.COM
Password:CINGULAR1 (yes this is in CAPS)
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
SECOND APN (radio button not selected)
Name
APN2
APN
wap.cingular
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
Not set
MMS proxy
Not set
MMS port
Not set
MCC
310
MNC
410
Authentication type
None
APN type
dun
APN protocol
Not set
Bearer
Not set
