Arc, SD Card, AFter Update Problems
Hi, i need some help here...
I already update to the new software, di aybody have the same problem with me??? after using app, when back to home sreen, it shows lags,, and slow to load the icon!,, what happen ? on the previous firmware, i never seen something like that before...
2. i want to ask , about the apps, i upgrade my sd card to 16 gb, all the apps ( paid and free ) i move to my old sd card, with app2sd,,, i copy all the content to my pc, and then copy again all the data to the new one sd card,
all the contents shows, but why , the app that i already donload and instal , i cant acces them? it didnt show up on my phone?
how, to get all the apps back? do i have to download and instal the app again???
is the way i do to move the app already corretct? or it not just the simple to move apps?
i need your respons ^_^, please help ^_^
thanks so much
7 REPLIES 7
first things first, try to move all the apps 2 SD that will speed things up, are you using a task killer? how about heavy apps like video games, or yahoo mail, etc?
you probably need to redownload the apps again
for future reference don't worry so much on the apps2sd app and if you want to backup everything check this methods
Backup & Restore app
Use this links to download the apk
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
First thing answer 🙂 = i already move all the apps to sd card ( with the same condition ) the lags never happen on the old firmware )
2. yo you mean, that id doesnt enough with the method( just copy by windows ) and cop paste again to the other sd card ).... its mean , the correct way, is using app backup and restore right ???
on the post above, i didnt find like the picture shows ( about log in to android market, and open my library , and send the app to my phone ) ,
3. is it okay, to format the sd card ( i mean are there an important content in sd card that conected to my phone system )??
hope you understand what i wrote,, hehehe,,, english is not my main language,, heheh
thanks the respond before ^___________^
you can't just copy the files from a SD card and paste it, this is the best way to do it
on your PC
1) open any folder -> click on tools -> properties -> view -> show hidden files
2) mount your phone with the NEW SD card and delete everything (save any file that you might want to keep)
3) swap SD cards, mount the old SD card, go to your SD card, press Ctrl + A then Ctrl C, on your desktop create a new folder, open it, then press CTRL + V
4) swap SD cards, mount the new SD card, open the folder you just created, press Ctrl + A then Ctrl C, open your SD card, Ctrl + V
android market varies from country to country, that's how the market looks here in the US
and it's important that you backup the hidden files aswell before you reformat your SD card
ohh, i see,,, thanks uliwooly,,, ^_^
and what the best way to format the sd card? or just enough to CTRL A and del ?
the best way is to mount the SD card to the computer, then go to Computer/my computer, right click on it choose reformat
