android market log in problems
hi my arc can connect and browse the web but the android market app cannot connect to google to sign in. but from the web browser i can log in to the android market website. how can i fix this? i've tried to log in to the android market app many many times but it doesnt connect. help. thanks!
28 REPLIES 28
i am also having the problem of not able to log into my android market. everytime i try, is says : 'cant establish a reliable data connection to the server.
thhis could be a temporary problem or your phone may not be provisioned for data services. if continues, call customer care.'
sooo what am i suppose to do?? pls reply asap
gwhispererz
Hi Isabella, factory reset phone and sign in to your GMail account.
Just note that this process will erase phone data completely, backup if necessary.
Have been having problems trying to access the android market as per posts above.
Nothing.
message returned stating username and password do not match.
I have had 2 other people try to access the market on this Xperia S also, and they receive the same m essage.
I have done factory reset and also tried the You Tube sign in and nothing.
Any clues....
gwhispererz
Hi Smee323, in that case, have you tried Software Repair?
Here's the download link to Update Service, http://www.sonymobile.com/gb/tools/update-service/
Download and install to PC/Laptop, launch it and follow on-screen instructions. Be aware that this process will erase phone data completely, backup if necessary.
hi.
Downloaded software, but get error message stating you have the latest build.  Phone has .67 and latest build is 73.  Will wait for ICS to arrive and see how we go.
Resolved Market/Play Store issue.
Seems Google have been rolling out duel verification on certain accounts.  Mine was one.  It was set ages ago on registration and had not previously caused problems. Most devices are not handling this "Feature " well.
Got into Google account, and reset verification settings and took backup of confirmation codes and downloaded them to the phone.
Also added phone as part of the 2 step process and resolved the code issue through Google Authentication App.
Took about 2 hours to figure it all out with one of my service providers Andriod tech guru's, but all sweet now.  Tech Guru had it happen to him a day or so previous and it took a while for him to figure it out.  Says he might start seeing more pepole experience this problem now 2 step process is in force.
gwhispererz
Glad that your problem is sorted out and thanks for the info.
manong
Hey, I have the exact same problem as isabella. I tried a factory reset but the sad part is that it deletes everything including my phone configuration and so when the phone startsup and the system says it will now connect to the internet bt ,lol, it cannot connect as it doesnt hav the required network connection n so I cannot log in to my account during initial setup. And by the time I get the required config from the service provider I cannot login. Btw we do not hav wifi around here so its not an option sadly. one more thing, I cannot seem to b able to connect wit any of my apps that comes bundled with the phone i.e. Facebook and youtube n also SE sync plus m unable to download anything of size bigger than in kbs, I get a- size too big messge. . please help if possible. Thanks.
gwhispererz
Hi manong, did you try all the possible solution in this thread?
eleazaranasco
try using SUS or repair your unit via pc suit. wala pa naman ako nagiging problema after doing it as of now. the thing is im doing setup via wifi.
