I did a software update this morning around 10am..Now after 5 hours, the phone is unable to restart...It keeps showing " Android is starting..Optimising application xx of 233..." What should i do? Please help... Thank you.
Update/repair the device with PCC, as far as the last statement.
@Eyan1 wrote:
I swear will not use or recommend sony to anyone
this is a user based forum, and a comment like that might not be the way to go, if that's how you feel about Sony that's on you but let them know directly >>> Local support
I have the same problem.
Now going through the downloading, optimising App stage, it is now stuck at the Android is starting. Already more than 24 hours since I started to do the update.
Really really mad at this.
I understand your frustration. I sought help from my local support. Below are their suggestions :
kindly be advised to try these methods one after the other if you are still experiencing it. Verify after each method whether the problem was solved, before trying the next one.
I removed the sim and memory card, let it sit for awhile and reinsert the sim only.
It manage the start up and works.
Attempt to reinsert the memory card goes back into the App optimising routine.
So now using the phone without the memory card.
Bad update.
I removed sd and SIM. Multiple restarts, still no joy. I got this phone for only 4 days. Don't even know about the pc support. I'm just gonna go give it back.
