Android driver for usb debuging in Xperia Tipo
vineeshm
Hi
When I was trying to debug an application in Xperia Tipo I enabled 'usb debugging' then it is showing Android driver not found so updated my PC Companion but no change.After that I got a link for 'Sony Xperia USB drivers' from google development forum but it does not have the driver for Sony Xperia Tipo... Slightly_frowning_Face  Anybody hav any solution.......
here is the link
http://developer.sonymobile.com/downloads/drivers/
2 REPLIES 2
vineeshm
screen shot of the error message
Rickard
This driver should be installed by PC Companion (http://www-support-downloads.sonymobile.com/Software%20Downloads/PC%20Companion/Sony%20PC%20Companio...)
If installing PC Companion doesn't help you could also use the USB-drivers in the Android SDK. You will however need to force that installation from the device manager in Windows.
Select update driver for the device from the device manager, select the 2:nd option, select the 2:nd option, click the have disk option and browse to the driver folder where you installed the SDK. In my PC it's C:\android-sdk-windows\extras\google\usb_driver.
