I noted the following problems....hope others having problems will post here to get a good response from sony...
1. My phone is slow even though I uninstalled most of the applications I used in 4.1.
2. (maybe the same problem) my remaining ram is around 190 and 200 even though i have disabled most of the applications.
3. phone in battery saver and stamina mode on for 8 hours battery draind 8 percent..( 4.1 It never happened)
4. Screen is sort of blinking when waking up...
5. Led notification light keeps on during the call....
6. Autobrightness is not working as promised to correct it.....
is it worth to have a phone like this???????????
shame on you sony you took so long for this update, finally to produce a **bleep** like this...????
For the volume bar,it seems you need to change theme to default,after that just restart the phone.
i have the same all bugs!! the mobile bravia engine don't work....... the led is bad, the volume bar too.... the camera............. pff
i've tried 4.3. update and it's not good at all and unless you know how to reflash your phone to the previous version personally I wouldn't recommend the 4.3. update.
I've reflashed mine back to 254 and won't be installing 4.3 again in it's current build.
it amazes me that 3 pre-releases later the final release build is so bad.
Think it's time to change brands which is very disappointing from Sony.
As for 4.4 Kit Kat I think I'll be a Samsung owner before they suss that one out.
Very Disappointed Sony Fan
I have used sony update service and at least, phone performance is generaly smooth, but some bugs still remain though. And the phone is a bit slower, than 4,1 anway. I am disapointed. Cannot wait for another update, that should fix that.
And sony, I would love to see kitkat on this phone ASAP. Please! You should leave 4.3 after the fix and work on 4.4
