Stupid, but real, everything was fine until I updated to .253.
I always use the album to see a picture while I'm using the bluetooth to listen music. I never had an issue. Now, when I click on the album, the picture takes something like 30 seconds to load and if I press the home or back button too much, the "Album not responding; Wait/Close" message appears.
Can anyone try? I believe this should be a general issue. I tried different bluetooth devices with the same result.
I've tested this but can't find any problem.
Do you have an SD-card in the phone and if so, what happens if you remove it? If you have a slow SD-card it might take longer to open a picture from it while you're reading a music file from it.
If that's not the case i recommend that you clear data for both Album and Media storage under Settings -> Apps -> All and then restart the phone.
Hi, Thanks for your answer.
Unfortunately the problem persists. Let me clear things out
Album freezes when you try to open it while you are already connected to a bluetooth device such as the Smart Wireless Pro.
Music is located on a 16GB class 10 Patriot memory.
All pictures are saved in the internal memory of the XZ.
Thanks in advance! I'm still on .253
