Hello, yesterday I decided to use battery care feature for the first time.
Before going to bed I set few alarms (as usually I do not wake up with first), plugged the charger in and the phone asked me if I want to use this feature. I selected "yes". The system told me when charging will reach 100%. Cool.
New icon has appeared i the upper left corner (status bar) and I went to sleep. In the morning I woke up on my own and notice there was no any alarm! It didn't wake me up! I checked the phone and it was turned off. It was just showing big battery icon but no Android system was running! I tried to boot it several times but it was hanged. Finally I powered it on and saw it was charged but as it hanged /turned off itself I was very late to the office, I overslept
Now I worry to use this feature again not to be late to the office, I cannot afford it. I will try to use it again but during weekend.
Can someone help? Is it working for you or this is a software bug?
Thank you.
You should keep testing it, you can do it at any time during the day
Based on what azzido wrote, I assume his phone had shut down while charging. That's not a function of the battery care system. Probably some app hanged the system and the phone shut down. I've been using the battery care function and it's working flawlessly so far. You should check your apps and see if one of them is prone to instability or malfunction.
ikramkhasim, I think you should just keep using it normally, it will adjust itself since it works and adjusts itself with the statistics of your subsequent chargings.
I'm on firmware 39.0.A.1.250 and Battery Care does NOT work with alarms. Others have reported the same.
Not 0like previously, so alarm rang, but I would expect to lose 1 to 1% of battery over night and not 86% right? Definitely something is wrong with Battery Care mode and when charging the phone to max 100%.
