Again, some of my ideas.
passlogin
just want to know, why did you integrate update center for system application? You can release it in the market, right (like smart connect)?
Also, if possible to disable power saver and enable multiple mode with priorities (e.g. when your battery dries, the automatic saver goes on, and when night the timer saver goes on too, but if two of those savers are egible to start, an priority list will configure which saver goes on, and add a feature to enable displaying the battery meter all the time, with different color when no saver or when power saver is on.
The last one is, remember my thread earlier? (it went so messy though)
-Why did sony releases ics, but there are some apps that seems to use the GB Code/theme? was you in rush?
The xperia gallery makes 700mb of thumbnails inside my int. storage!
I hope with the next update, sony will fix 'em
Johan
Thank you for your input I will try to pass these on as well.
