An app cause that. Try find it..if you cant then list apps here
Are you receiving any ad in the status field? If yes, you can drag down the status field > press and hold at the ad > choose "app info" and you should be able to find which app that is causing this.
Otherwise, you could download an application with an ad detection function from Google Play. You can search on "ad detector" and you should be able to find some apps with this function.
try bboot in safe mode see popup shows again?
if yes i think you must perform another factory reset
Have you tried an ad detector application? If you cannot find which app that is causing it by an ad detector or on your own (for example check the reviews for the apps that you have downloaded) you might need to uninstall app by app to see if the advertising stops.
Unfortunately, you need to uninstall one app at a time to see when the advertise stops. Or vice versa, uninstall all apps and install one by one to see when the advertise starts.
what apps do you have?
list them here maybe we can help then
