I'm getting a lot of things not responding lately which does'nt bother me much, but activity phone not responding is becoming an irretation. how do I fix it? A phone to me is to get and make calls. This error prevents me from answering call/oppertunities.
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
@graeme2603 wrote:I'm getting a lot of things not responding lately which does'nt bother me much, but activity phone not responding is becoming an irretation. how do I fix it? A phone to me is to get and make calls. This error prevents me from answering call/oppertunities.
Hi, do you mean that when you get an incoming call the screen stays black stopping you from answering
Hi graeme2603,
You could try clearing the data from the Home screen.
Menu > Settings > Apps > All > Xperia Home > Clear Data
let us know if this helps.
