Hi.
I have a little bit complicated problem.
Some days ago I updated to ICS. I had a couple of reboot in the next to days, or I had to remove the battery because the power button was not working (then it was not possible to unlock the screen).
Then, when I run out of battery, I discovered it was not possible to charge anymore.
If I connect to the PC through USB, Win fails to find the MTP drivers (but I already used the phone on the PC), and it is even not charging the phone. PC companion fails to connect..ok the phone is off.
If I use the standard power supply, it is not charging. If I remove the battery, and then put in again, the led becomes green, but if I try to switch on, I have a small vibe but nothing else.
The green led dissapears and I have to repeat the procedure for the battery.
This lets me think it could be a SW problem in something like the boot up.
Do you have any idea how to solve the problem?
Try to repair your phone's software
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Hi, I followed the procedure but probably it doesn't work.
I arrived at step 2, plugged in the USB in the mobile pressing the volume down, but nothing happened.
I only got a red led flashing on the phone, and the error from windows that it cannot recognize the USB device
I made a step forward...I repeated the procedure removing temporarerly the battery from the phone, not just switching off..
I went forward till point 4, but when I try to switch on the phone, I only get still the red flashing led....
You will have to charge your mobile for 2-3 hours atleast
After charging if it doesn't starts up then give software repair a go
Red led means battery is low
After some work I think I succeded to charge the battery (I had to plug-unplug the battery several times in order to have the led on for the charging).
Now every time I plug in the charger, the light is green.
No way to have it on, anyway.
I tried again a couple of times the SW repair, it had worked, but anyway all I get when I try to switch on is a small vibe, no real boot up.
You will have to get it check at support center then
