Yes, I only use Walkman app.
What if you boot on safe mode?
In headphone selection menu i've selected 'STH 30' which is gives powerfull music.
But after I come out completely from the player, and after a while turn on the music again, the whole power of the sound disappears, although there is a check mark STH-30... Every time i play music i need to reselect the STH-30 option.
please fix this issue ... 😞
Yes, same here.
Especially apps like YouTube which overwrites the selected Headset profile.
Always have to reselect again.
Sometimes it works and sometimes it just doesn't work, especially when you have used another app that outputs sound.
I'll try that Safe Mode to see if it works.
Right now, I've updated my Z Ultra to 5.1 and the same problem persists. And that headset selection for sound output quality only happens to be in Music (Previously Walkman) app with ClearAudio+ turned ON. When switched to another app like Youtube, the selected settings's sound output quality is reset back to "General Headset" output (I use MH750).
It is really annoying in a way when you want to listen to a HQ music with the best output.
i have been also experiencing this issue, end of every Mp3 songs headphones settings changed into general. need to set again and again for every songs, this bug makes the listing experince bad.
