about my recent xperia problems
shresthasaurav4
My phone turns off and then restart, again turn off and then restart, continuously for a long time, when I turn on wi-fi, bluetooth, FM radio and sometimes even when airplane mode is turn on after it is made off. Today It showed up similar problem when I turn my mobile data and it is still showing the symptoms since morning making me unable to use it. sometimes it will recover soon. But many times it becomes very hot before it begins to switch off.
I have known sony to be the best in terms of hardware and all it manufactures before buying it eagerly. I know it will be the best in coming days. But Can it brings me solution to my problems.
I would be very eager to thank you. Please give me the chance.
Thommo
Genius
You may need to perform a repair
Switch off your phone and unplug from Pc
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
