A dot in camera
oatbits
A dot in camera
A "dot " came up yesturday and will not dissapear, what is wrong??
It is like some kind of dirt is in the way, but it isnt dirt..
3 REPLIES 3
Does your phone has a protective film? It could be dirt
Also, it could be a dead pixel, download Xperia diagnostics and test the screen
Jake-SonyXperia
Hi oatbits,
Generally a Dot in the camera is as Uliwooly says a dead pixel, it can however be related to software.
I would suggest performing a backup of content and then trying a software repair using PC Companion.
1. Before you start you have to download the PC Companion software from PC Companion
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
