6.0.1 poor network connection
cjbchris
Since updating to 6.0.1 I have had real problems with Lte connectivity..
I had great reception under previous android, but now it hardly connects for data (calls seem to be okay)..
I've tried wcdma preferred, but it doesn't appear to make any difference.
Anyone else got this problem, or any solutions?
Tags (3)
30 REPLIES 30
@cjbchris @cjkgt97
Could you try a different SIM card?
are you the same user with those 2 accounts?
cjbchris
I'll give Virgin a shout for a new sim.. And no.. I only got one account.
Chris
cjkgt97
If the SIM was bad, how would I get it to reconnect?  This is not a SIM problem.  If the SIM was bad, voice wouldn't work much less data.
Happened again to me on the way to work today.  There is one spot on my commute where I lose signal for about 5 - 10 seconds and that was enough to completely disable data on my device.
I checked my IP utility and I had IPv6 addresses for my radio interface, gateway, and DNS servers.  The addresses are there, but the packets aren't getting through.
Rickard
I'm very sorry to hear that Slightly_frowning_Face
First go to Settings -> More -> Mobile networks -> Access Point Names -> [your APN]. Here make sure "APN protocol" is set to IPv4/IPv6 and not IPv6.
If this doesn't help, would it be possible for you to send me a private message with some information about your phones and also a log taken after this has happened?
First open the dialer and dial *#*#7378423#*#*, select Service info -> Model info and note the model number.
Then go back to "Service info"  and select "Software info". Take a screenshot, scroll down and take another screenshot.
Go back to "Service info", select "Configuration" and take a screenshot.
To take a log:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- The next time you don't get network connection:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive.
Please send me model number, screen shots and a link to the file on Google Drive in a private message and i'll forward this internally for investigation.
cjbchris
Thanks..
I just got new Sim card and the issue still remains.
Rickard
Could you check so that the APN-protocol setting is set to IPv4/IPv6 under Settings -> More -> Mobile networks -> Access Point Names -> [your APN]?
cjbchris
Hi..yes it is.. Just preparing pm for you
cjbchris
Ok.. Hands up.. I got it sorted, eventually..
My provider has changed its APN settings, when I downloaded them, it downloaded the old settings.. It's only taken 3 days of trawling the internet to find the new ones.
Just wanna say thanks to the Sony guys on here for offering their assistance with this.
Chris
cjkgt97
Rickard,
My APN was set to IPv6 only.  I have switched it to IPv4/IPv6.  I will respond if the problem clears up and I will also get you the logs.  Prior to changing the setting it happened again twice this morning.
jimboz10
I've had Xperia z2 (D6503) for almost 2 years now. 2 weeks ago i updated my phone to android marshmallow from lolipop. After the update was done, my LTE connection didn't work at all even though my area is covered. LTE worked flawlessly before i updated to Android M. I have 4G LTE nano SIM card, it worked fine on other phone, APN setting is also fine. Also, my phone needs about 4-6 hours to charge from about 20% to 100%, meanwhile, before i updated to marshmallow, it took only 3-4 hours.  Other than that, my battery drains really fast (compared to when i was using lolipop ). Please help me to fix these problems. Thanks in advance.
