I was wondering if there was any way to get a 3rd party LED control app to work even while stamina mode is active since, activating stamina mode overrides all the settings being used while normal use.
To quote member Archanos word for word
This will do the trick
https://play.google.com/store/apps/details?id=com.koo.lightmanager
but remember, to make such an app actually work, you have to uninstall every single app that does the same but the one you are going to use, and before uninstalling any app that uses the phone's hardware you need to disable it in "device administrators". If you don't uncheck it first, it may leave some settings behind not restored to defaults, and this might cause many problems.
Just make sure you use one app at the time, this one is confirmed to work (runs like a charm in my Z1).
Oh, and BTW: for apps like this (Whatsapp) you need a root access. I doubt it can be done any other way (I couldn't find one so far). So perhaps if you need only this one work with notifications.. well, you will have to wait for root to be safe on Z1, because now it will break the camera functionality. Perhaps someone found already an app that works with Whatsapp without the root, I didn't yet.
